Date/Time: Fri, 26 Apr 2024 04:28:11 +0000
Date range in file
View Count: 1557
[2013-05-18 19:14:47] |
mayerrs - Posts: 70 |
Hi, i have this problem. I want to start new intraday chart and here is what i get. I want to get 30 prior days and range file strats 05/31/2011. And than it may take an hours to download the rest. Can you help me to fix it. I am not sure if i may have something wrong.
20130518 01.png / V - Attached On 2013-05-18 19:14:41 UTC - Size: 42.82 KB - 497 views |
[2013-05-20 17:15:35] |
Please refer to help topic 37 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails37.html Make sure the Maximum Historical Intraday Days to Download is not set too high. We recommend not higher than 60. After that change, go to the chart and select Edit >>Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-20 17:16:12
