Date/Time: Wed, 05 Feb 2025 09:44:15 +0000
activation
View Count: 1227
[2014-12-03 14:43:44]
User88278 - Posts: 7
i receive an info i need to open a ticket to activate
could you do that?please
[2014-12-03 15:49:58]
Sierra Chart - Max - Posts: 5786
Your account has been activated and/or reset.
A restart is necessary if Sierra Chart is already running. Exit the Sierra Chart charting and trading software by selecting "File >> Exit". Open Sierra Chart through the icon on your desktop or through the desktop Start menu.
After your Sierra Chart usage time ends, you need to pay for additional usage time through "Help >> Add Usage Credit".
Sierra Chart Support
[2014-12-03 16:16:15]
i did that, i receive a mesage , reconecting, waiting for reconect, reconecting...but never conect
[2014-12-03 18:39:50]
Provide a copy of the Message Log, by following these instructions:
http://www.sierrachart.com/index.php?l=PostingInformation.php#log
[2014-12-03 18:51:11]
Software version: 1214 | 2014-12-03 12:48:34
Uses Old Spreadsheets | 2014-12-03 12:48:34
Usage end date: 2014-12-18 | 2014-12-03 12:48:34
Enabled for: Advanced Features. | 2014-12-03 12:48:34
Enabled for: Advanced Features 2. | 2014-12-03 12:48:34
Enabled for: Sierra Chart Historical Data Service. | 2014-12-03 12:48:34
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-12-03 12:48:34
Active service: Rithmic Trading | 2014-12-03 12:48:34
Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-12-03 12:48:34
2014-12-03 13:48:34 Local computer clock time | 2014-12-03 12:48:34
2014-12-03 18:48:34 GMT time | 2014-12-03 12:48:34
2014-12-03 12:48:34 Time zone adjusted time | 2014-12-03 12:48:34
Time difference to server time: 1 seconds. | 2014-12-03 12:48:34
Program path: C:\SierraChart\ | 2014-12-03 12:48:34
Data Files path: C:\SierraChart\Data\ | 2014-12-03 12:48:34
OS Version Number: 5.2 | 2014-12-03 12:48:34
Locale Information: C | 2014-12-03 12:48:34
Checking for new symbol settings for rim | 2014-12-03 12:48:34
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 88.198.13.175 | 2014-12-03 12:48:34
HTTP connection to www.sierrachart.com:80 (1136) | Connected. | 2014-12-03 12:48:34
Requesting symbol settings for rim. Overwrite = on. | 2014-12-03 12:48:34
Rithmic Trading | Port for executable: 2255 | 2014-12-03 12:48:39
Listening socket (1528), port 2255 | Closed. | 2014-12-03 12:48:39
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:48:39
Symbol settings received. | 2014-12-03 12:48:40
Processed received symbol settings | 2014-12-03 12:48:40
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2255 | 2014-12-03 12:48:41
Socket (1540) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:48:42
Socket (1540) | Shutdown and closed. | 2014-12-03 12:48:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:48:42
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:48:42
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:48:42
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:48:42
Rithmic Trading | Port for executable: 2257 | 2014-12-03 12:48:44
Listening socket (1536), port 2257 | Closed. | 2014-12-03 12:48:44
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:48:44
HTTP connection to www.sierrachart.com:80 (1136) | Closed. No error. | 2014-12-03 12:48:44
HTTP connection to www.sierrachart.com:80 (1136) | Shutdown and closed. | 2014-12-03 12:48:44
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2257 | 2014-12-03 12:48:46
Socket (1124) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:48:47
Socket (1124) | Shutdown and closed. | 2014-12-03 12:48:47
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:48:47
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:48:47
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:48:47
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:48:47
Rithmic Trading | Port for executable: 2260 | 2014-12-03 12:48:49
Listening socket (1532), port 2260 | Closed. | 2014-12-03 12:48:49
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:48:49
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2260 | 2014-12-03 12:48:51
Socket (1240) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:48:52
Socket (1240) | Shutdown and closed. | 2014-12-03 12:48:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:48:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:48:52
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:48:52
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:48:52
Rithmic Trading | Port for executable: 2262 | 2014-12-03 12:48:54
Listening socket (1124), port 2262 | Closed. | 2014-12-03 12:48:54
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:48:54
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2262 | 2014-12-03 12:48:56
Socket (1532) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:48:57
Socket (1532) | Shutdown and closed. | 2014-12-03 12:48:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:48:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:48:57
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:48:57
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:48:57
Rithmic Trading | Port for executable: 2264 | 2014-12-03 12:48:59
Listening socket (1136), port 2264 | Closed. | 2014-12-03 12:48:59
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:48:59
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2264 | 2014-12-03 12:49:01
Socket (1124) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:49:02
Socket (1124) | Shutdown and closed. | 2014-12-03 12:49:02
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:49:02
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:49:02
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:49:02
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:49:02
Rithmic Trading | Port for executable: 2266 | 2014-12-03 12:49:04
Listening socket (1240), port 2266 | Closed. | 2014-12-03 12:49:04
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:49:04
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2266 | 2014-12-03 12:49:06
Socket (1136) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:49:07
Socket (1136) | Shutdown and closed. | 2014-12-03 12:49:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:49:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:49:07
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:49:07
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:49:07
Rithmic Trading | Port for executable: 2268 | 2014-12-03 12:49:09
Listening socket (1124), port 2268 | Closed. | 2014-12-03 12:49:09
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:49:09
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2268 | 2014-12-03 12:49:11
Socket (1240) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:49:12
Socket (1240) | Shutdown and closed. | 2014-12-03 12:49:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:49:12
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:49:12
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:49:12
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:49:12
Rithmic Trading | Port for executable: 2275 | 2014-12-03 12:49:14
Listening socket (1136), port 2275 | Closed. | 2014-12-03 12:49:14
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:49:14
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2275 | 2014-12-03 12:49:16
Socket (1124) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:49:17
Socket (1124) | Shutdown and closed. | 2014-12-03 12:49:17
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:49:17
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:49:17
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:49:17
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:49:17
Rithmic Trading | Port for executable: 2294 | 2014-12-03 12:49:19
Listening socket (1240), port 2294 | Closed. | 2014-12-03 12:49:19
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:49:19
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2294 | 2014-12-03 12:49:21
Socket (1136) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:49:22
Socket (1136) | Shutdown and closed. | 2014-12-03 12:49:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:49:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:49:22
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:49:22
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:49:22
Rithmic Trading | Port for executable: 2296 | 2014-12-03 12:49:24
Listening socket (1124), port 2296 | Closed. | 2014-12-03 12:49:24
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:49:24
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2296 | 2014-12-03 12:49:26
Socket (1240) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:49:26
Socket (1240) | Shutdown and closed. | 2014-12-03 12:49:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:49:26
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:49:26
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:49:27
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:49:27
Rithmic Trading | Port for executable: 2298 | 2014-12-03 12:49:29
Listening socket (1136), port 2298 | Closed. | 2014-12-03 12:49:29
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:49:29
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2298 | 2014-12-03 12:49:31
Socket (1124) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:49:31
Socket (1124) | Shutdown and closed. | 2014-12-03 12:49:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:49:31
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:49:31
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:49:31
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:49:31
Rithmic Trading | Port for executable: 2300 | 2014-12-03 12:49:33
Listening socket (1240), port 2300 | Closed. | 2014-12-03 12:49:33
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:49:33
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2300 | 2014-12-03 12:49:35
Socket (1136) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:49:36
Socket (1136) | Shutdown and closed. | 2014-12-03 12:49:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:49:36
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:49:36
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:49:36
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:49:36
Rithmic Trading | Port for executable: 2302 | 2014-12-03 12:49:38
Listening socket (1124), port 2302 | Closed. | 2014-12-03 12:49:38
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:49:38
File >> Disconnect selected. | 2014-12-03 12:49:39
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:49:39
Rithmic Trading | Port for executable: 2303 | 2014-12-03 12:49:41
Listening socket (1136), port 2303 | Closed. | 2014-12-03 12:49:41
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:49:41
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2303 | 2014-12-03 12:49:43
Socket (1124) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:49:43
Socket (1124) | Shutdown and closed. | 2014-12-03 12:49:43
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:49:43
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:49:43
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:49:44
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:49:44
Rithmic Trading | Port for executable: 2305 | 2014-12-03 12:49:46
Listening socket (1240), port 2305 | Closed. | 2014-12-03 12:49:46
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:49:46
Service is currently connecting. | 2014-12-03 12:49:47 *
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2305 | 2014-12-03 12:49:48
Socket (1136) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:49:49
Socket (1136) | Shutdown and closed. | 2014-12-03 12:49:49
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:49:49
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:49:49
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:49:49
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:49:49
Rithmic Trading | Port for executable: 2307 | 2014-12-03 12:49:51
Listening socket (1124), port 2307 | Closed. | 2014-12-03 12:49:51
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:49:51
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2307 | 2014-12-03 12:49:53
Socket (1240) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:49:54
Socket (1240) | Shutdown and closed. | 2014-12-03 12:49:54
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:49:54
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:49:54
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:49:54
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:49:54
Rithmic Trading | Port for executable: 2309 | 2014-12-03 12:49:56
Listening socket (1136), port 2309 | Closed. | 2014-12-03 12:49:56
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:49:56
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2309 | 2014-12-03 12:49:58
Socket (1124) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:49:59
Socket (1124) | Shutdown and closed. | 2014-12-03 12:49:59
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:49:59
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:49:59
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:49:59
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:49:59
Rithmic Trading | Port for executable: 2311 | 2014-12-03 12:50:01
Listening socket (1240), port 2311 | Closed. | 2014-12-03 12:50:01
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:50:01
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2311 | 2014-12-03 12:50:03
Socket (1136) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:50:04
Socket (1136) | Shutdown and closed. | 2014-12-03 12:50:04
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:50:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:50:04
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:50:04
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:50:04
Rithmic Trading | Port for executable: 2313 | 2014-12-03 12:50:06
Listening socket (1124), port 2313 | Closed. | 2014-12-03 12:50:06
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:50:06
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2313 | 2014-12-03 12:50:08
Socket (1240) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:50:09
Socket (1240) | Shutdown and closed. | 2014-12-03 12:50:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:50:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:50:09
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:50:09
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:50:09
Rithmic Trading | Port for executable: 2315 | 2014-12-03 12:50:11
Listening socket (1136), port 2315 | Closed. | 2014-12-03 12:50:11
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:50:11
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2315 | 2014-12-03 12:50:13
Socket (1124) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:50:13
Socket (1124) | Shutdown and closed. | 2014-12-03 12:50:13
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:50:13
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:50:13
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:50:13
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:50:13
Rithmic Trading | Port for executable: 2321 | 2014-12-03 12:50:15
Listening socket (1240), port 2321 | Closed. | 2014-12-03 12:50:15
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:50:15
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2321 | 2014-12-03 12:50:17
Socket (1136) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:50:18
Socket (1136) | Shutdown and closed. | 2014-12-03 12:50:18
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:50:18
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:50:18
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:50:19
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:50:19
Rithmic Trading | Port for executable: 2323 | 2014-12-03 12:50:21
Listening socket (1124), port 2323 | Closed. | 2014-12-03 12:50:21
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:50:21
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2323 | 2014-12-03 12:50:23
Socket (1240) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:50:24
Socket (1240) | Shutdown and closed. | 2014-12-03 12:50:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:50:24
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:50:24
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:50:24
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:50:24
Rithmic Trading | Port for executable: 2325 | 2014-12-03 12:50:26
Listening socket (1136), port 2325 | Closed. | 2014-12-03 12:50:26
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:50:26
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2325 | 2014-12-03 12:50:28
Socket (1124) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:50:28
Socket (1124) | Shutdown and closed. | 2014-12-03 12:50:28
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:50:28
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:50:28
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:50:28
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:50:28
Rithmic Trading | Port for executable: 2327 | 2014-12-03 12:50:30
Listening socket (1240), port 2327 | Closed. | 2014-12-03 12:50:30
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:50:30
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2327 | 2014-12-03 12:50:32
Socket (1136) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:50:33
Socket (1136) | Shutdown and closed. | 2014-12-03 12:50:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:50:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:50:33
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:50:33
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:50:33
Rithmic Trading | Port for executable: 2330 | 2014-12-03 12:50:35
Listening socket (1124), port 2330 | Closed. | 2014-12-03 12:50:35
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:50:35
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2330 | 2014-12-03 12:50:37
Socket (1240) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:50:38
Socket (1240) | Shutdown and closed. | 2014-12-03 12:50:38
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:50:38
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:50:38
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:50:38
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:50:38
Rithmic Trading | Port for executable: 2334 | 2014-12-03 12:50:40
Listening socket (1136), port 2334 | Closed. | 2014-12-03 12:50:40
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:50:40
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2334 | 2014-12-03 12:50:42
Socket (1124) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:50:43
Socket (1124) | Shutdown and closed. | 2014-12-03 12:50:43
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:50:43
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:50:43
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:50:43
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:50:43
Rithmic Trading | Port for executable: 2336 | 2014-12-03 12:50:45
Listening socket (1240), port 2336 | Closed. | 2014-12-03 12:50:45
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:50:45
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2336 | 2014-12-03 12:50:47
Socket (1136) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:50:48
Socket (1136) | Shutdown and closed. | 2014-12-03 12:50:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:50:48
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:50:48
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:50:48
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:50:48
Rithmic Trading | Port for executable: 2338 | 2014-12-03 12:50:50
Listening socket (1124), port 2338 | Closed. | 2014-12-03 12:50:50
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:50:50
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2338 | 2014-12-03 12:50:52
Socket (1240) | Error received in OnConnect while connecting. Windows error code 10061: No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. | 2014-12-03 12:50:53
Socket (1240) | Shutdown and closed. | 2014-12-03 12:50:53
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:50:53
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:50:53
Rithmic Trading | Disconnected from the server. | 2014-12-03 12:50:53
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:50:53
Rithmic Trading | Port for executable: 2340 | 2014-12-03 12:50:55
Listening socket (1136), port 2340 | Closed. | 2014-12-03 12:50:55
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 12:50:55
[2014-12-03 18:57:20]
Sierra Chart supports Windows XP but it is not supported by the Rithmic software. So it is not possible to use Rithmic on a computer with Windows XP.
[2014-12-03 19:03:05]
ok i will to re install on another pc
i need something for you to do that?
thanks
[2014-12-03 19:04:51]
No, there is nothing we need to do. You can install Sierra Chart on any computer you want. Simply log in with your Sierra Chart Account Name and Password at the Sierra Chart Login window.
[2014-12-03 19:43:50]
Thank you
i have 3 charts 5,15,30 and i set Initial balance 20min in each , but in the 5 the result are ok, in the 15 and 30 not, how can i do to have 20min IB, on the 3?
thanks
[2014-12-03 19:47:54]
For a 20 minute Initial Balance, you must have a chart with the chart bars set to 20 minutes, or a bar period which evenly divides into 20 minutes.
You could also have a look at overlaying it from another chart. Refer to help topic 28 here:
http://www.sierrachart.com/index.php?page=doc/helpdetails28.html
