Date/Time: Thu, 10 Sep 2026 23:55:43 +0000
waiting to reconnect...
View Count: 1354
[2014-12-03 14:25:58]
User83963 - Posts: 18
can’t get a connection started yesterday evening and the same today.. getting the message waiting to reconnect…
[2014-12-03 16:30:40]
Provide a copy of the Message Log, by following these instructions:
http://www.sierrachart.com/index.php?l=PostingInformation.php#log
[2014-12-03 19:02:57]
Software version: 1212 | 2014-12-03 13:57:23
Uses Old Spreadsheets | 2014-12-03 13:57:23
Usage end date: 2014-12-23 | 2014-12-03 13:57:23
Enabled for: Advanced Features. | 2014-12-03 13:57:23
Enabled for: Advanced Features 2. | 2014-12-03 13:57:23
Enabled for: Sierra Chart Historical Data Service. | 2014-12-03 13:57:23
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2014-12-03 13:57:23
Enabled for: S&P INDEXES exchange. | 2014-12-03 13:57:23
Received 1 data feed usernames. | 2014-12-03 13:57:23
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-12-03 13:57:23
Active service: Rithmic Trading | 2014-12-03 13:57:23
Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-12-03 13:57:23
2014-12-03 13:57:23 Local computer clock time | 2014-12-03 13:57:23
2014-12-03 18:57:23 GMT time | 2014-12-03 13:57:23
2014-12-03 13:57:23 Time zone adjusted time | 2014-12-03 13:57:23
Time difference to server time: 0 seconds. | 2014-12-03 13:57:23
Program path: C:\SierraChart\ | 2014-12-03 13:57:23
Data Files path: C:\SierraChart\Data\ | 2014-12-03 13:57:23
OS Version Number: 6.1 | 2014-12-03 13:57:23
Locale Information: C | 2014-12-03 13:57:23
Checking for new symbol settings for rim | 2014-12-03 13:57:23
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 88.198.13.175 | 2014-12-03 13:57:23
HTTP connection to www.sierrachart.com:80 (1288) | Connected. | 2014-12-03 13:57:23
Symbol settings are up-to-date for rim | 2014-12-03 13:57:23
Rithmic Trading | Port for executable: 49285 | 2014-12-03 13:57:28
Listening socket (1796), port 49285 | Closed. | 2014-12-03 13:57:28
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 13:57:28
HTTP connection to www.sierrachart.com:80 (1288) | Closed. No error. | 2014-12-03 13:57:29
HTTP connection to www.sierrachart.com:80 (1288) | Shutdown and closed. | 2014-12-03 13:57:29
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49285 | 2014-12-03 13:57:30
Socket (1280) | Connected. | 2014-12-03 13:57:30
Rithmic Trading | Connected to server. | 2014-12-03 13:57:30
Rithmic Trading | Sending logon request message. | 2014-12-03 13:57:30
Rithmic Trading | Starting the connection process to data and trading service. | 2014-12-03 13:57:30
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-12-03 13:57:30
Rithmic Trading | Connecting to Rithmic 01 US server. | 2014-12-03 13:57:30
Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-12-03 13:57:32
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-12-03 13:57:32
Rithmic Trading | Server Name: DTC Bridge. | 2014-12-03 13:57:32
Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-12-03 13:57:32
Rithmic Trading | Logon error from server | 2014-12-03 13:57:32
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 13:57:32
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 13:57:32
Socket (1280) | Shutdown and closed. | 2014-12-03 13:57:32
Rithmic Trading | Disconnected from the server. | 2014-12-03 13:57:32
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 13:57:32
Rithmic Trading | Bridge process is still running. | 2014-12-03 13:57:34
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49285 | 2014-12-03 13:57:36
Socket (1288) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-03 13:57:37
Socket (1288) | Shutdown and closed. | 2014-12-03 13:57:37
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 13:57:37
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 13:57:37
Rithmic Trading | Disconnected from the server. | 2014-12-03 13:57:37
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 13:57:37
Rithmic Trading | Bridge process is still running. | 2014-12-03 13:57:39
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49285 | 2014-12-03 13:57:41
Socket (1280) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-03 13:57:42
Socket (1280) | Shutdown and closed. | 2014-12-03 13:57:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 13:57:42
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 13:57:42
Rithmic Trading | Disconnected from the server. | 2014-12-03 13:57:42
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 13:57:42
Rithmic Trading | Bridge process is still running. | 2014-12-03 13:57:44
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49285 | 2014-12-03 13:57:46
Socket (1288) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-03 13:57:47
Socket (1288) | Shutdown and closed. | 2014-12-03 13:57:47
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 13:57:47
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 13:57:47
Rithmic Trading | Disconnected from the server. | 2014-12-03 13:57:47
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 13:57:47
Rithmic Trading | Bridge process is still running. | 2014-12-03 13:57:49
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49285 | 2014-12-03 13:57:51
Socket (1280) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-03 13:57:52
Socket (1280) | Shutdown and closed. | 2014-12-03 13:57:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 13:57:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 13:57:52
Rithmic Trading | Disconnected from the server. | 2014-12-03 13:57:52
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 13:57:52
Rithmic Trading | Port for executable: 49300 | 2014-12-03 13:57:54
Listening socket (1800), port 49300 | Closed. | 2014-12-03 13:57:54
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 13:57:54
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49300 | 2014-12-03 13:57:56
Socket (1800) | Connected. | 2014-12-03 13:57:56
Rithmic Trading | Connected to server. | 2014-12-03 13:57:56
Rithmic Trading | Sending logon request message. | 2014-12-03 13:57:56
Rithmic Trading | Starting the connection process to data and trading service. | 2014-12-03 13:57:56
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-12-03 13:57:56
Rithmic Trading | Connecting to Rithmic 01 US server. | 2014-12-03 13:57:56
Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-12-03 13:57:58
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-12-03 13:57:58
Rithmic Trading | Server Name: DTC Bridge. | 2014-12-03 13:57:58
Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-12-03 13:57:58
Rithmic Trading | Logon error from server | 2014-12-03 13:57:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 13:57:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 13:57:58
Socket (1800) | Shutdown and closed. | 2014-12-03 13:57:58
Rithmic Trading | Disconnected from the server. | 2014-12-03 13:57:58
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 13:57:58
Rithmic Trading | Bridge process is still running. | 2014-12-03 13:58:00
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49300 | 2014-12-03 13:58:02
Socket (1288) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-03 13:58:03
Socket (1288) | Shutdown and closed. | 2014-12-03 13:58:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 13:58:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 13:58:03
Rithmic Trading | Disconnected from the server. | 2014-12-03 13:58:03
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 13:58:03
Rithmic Trading | Bridge process is still running. | 2014-12-03 13:58:05
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49300 | 2014-12-03 13:58:07
Socket (1800) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-03 13:58:08
Socket (1800) | Shutdown and closed. | 2014-12-03 13:58:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 13:58:08
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 13:58:08
Rithmic Trading | Disconnected from the server. | 2014-12-03 13:58:08
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 13:58:08
Rithmic Trading | Bridge process is still running. | 2014-12-03 13:58:10
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49300 | 2014-12-03 13:58:12
Socket (1288) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-03 13:58:13
Socket (1288) | Shutdown and closed. | 2014-12-03 13:58:13
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 13:58:13
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 13:58:13
Rithmic Trading | Disconnected from the server. | 2014-12-03 13:58:13
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 13:58:13
Rithmic Trading | Bridge process is still running. | 2014-12-03 13:58:15
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49300 | 2014-12-03 13:58:17
Socket (1800) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-03 13:58:18
Socket (1800) | Shutdown and closed. | 2014-12-03 13:58:18
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 13:58:18
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 13:58:18
Rithmic Trading | Disconnected from the server. | 2014-12-03 13:58:18
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 13:58:18
Rithmic Trading | Port for executable: 49315 | 2014-12-03 13:58:20
Listening socket (1784), port 49315 | Closed. | 2014-12-03 13:58:20
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-12-03 13:58:20
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49315 | 2014-12-03 13:58:22
Socket (1784) | Connected. | 2014-12-03 13:58:22
Rithmic Trading | Connected to server. | 2014-12-03 13:58:22
Rithmic Trading | Sending logon request message. | 2014-12-03 13:58:22
Rithmic Trading | Starting the connection process to data and trading service. | 2014-12-03 13:58:22
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-12-03 13:58:22
Rithmic Trading | Connecting to Rithmic 01 US server. | 2014-12-03 13:58:22
Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-12-03 13:58:23
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-12-03 13:58:23
Rithmic Trading | Server Name: DTC Bridge. | 2014-12-03 13:58:23
Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-12-03 13:58:23
Rithmic Trading | Logon error from server | 2014-12-03 13:58:23
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 13:58:23
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 13:58:23
Socket (1784) | Shutdown and closed. | 2014-12-03 13:58:24
Rithmic Trading | Disconnected from the server. | 2014-12-03 13:58:24
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 13:58:24
Rithmic Trading | Bridge process is still running. | 2014-12-03 13:58:26
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49315 | 2014-12-03 13:58:28
Socket (1076) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-03 13:58:29
Socket (1076) | Shutdown and closed. | 2014-12-03 13:58:29
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 13:58:29
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 13:58:29
Rithmic Trading | Disconnected from the server. | 2014-12-03 13:58:29
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 13:58:29
Rithmic Trading | Bridge process is still running. | 2014-12-03 13:58:31
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49315 | 2014-12-03 13:58:33
Socket (1112) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-03 13:58:34
Socket (1112) | Shutdown and closed. | 2014-12-03 13:58:34
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 13:58:34
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 13:58:34
Rithmic Trading | Disconnected from the server. | 2014-12-03 13:58:34
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 13:58:34
Rithmic Trading | Bridge process is still running. | 2014-12-03 13:58:36
[2014-12-03 19:19:18]
You are getting this error message from the Rithmic system:
Refer to step 17 here about a Permission Denied error:
http://www.sierrachart.com/index.php?page=doc/Rithmic.php#SetupInstructions
Date Time Of Last Edit: 2014-12-03 19:19:33
