Date/Time: Wed, 05 Feb 2025 09:43:26 +0000
U.S. Equities No Data How To Set Up Connection
View Count: 851
[2014-12-03 13:11:14] |
User23386 - Posts: 43 |
I just activated U.S. Equities as an additional exchange to what I have already. I am connecting via Rithmic. How to I go about getting U.S. Equities Data?? I know Rithmic is futures only so do I have to open up a 2nd copy of Sierra and connect to ? for the U.S. Equities data to work???
[2014-12-03 18:00:33] |
You can either get US equities data in the same copy of Sierra Chart using Rithmic, however we need to set this up, or install another copy of Sierra Chart following the instructions here: http://www.sierrachart.com/index.php?page=doc/MultipleServices.html For this other copy of Sierra Chart you need to set it to the "SC Exchange Data" Service. We are setting up US equities support for Rithmic now. Will be done in about 30 minutes. You will need to update the Symbol Settings at that time following these instructions: http://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
