Date/Time: Sat, 21 Dec 2024 13:24:49 +0000
[User Discussion] - Peaks & Valleys displayed on another chart
View Count: 1825
[2014-12-03 12:35:17]
Dom7364 - Posts: 257
What is the way to get peaks & valleys from the VP applied to a chart, to be copied over to another chart and displayed on it as horizontal lines with corresponding levels?
[2014-12-06 05:23:38]
I find it hard to believe nobody else has tried to do that? Obviously the idea is not to have a volume profile on a given chart and add the peaks & valleys, but to either copy over to the chart the peaks & valleys from another chart where VP is applied and showing them, or to be able to display P&V and why not other levels such as VA and POC from the VP on the chart without showing the volume itself (or a way to hide the VP itself).?
[2014-12-06 15:44:02]
crazybears - Posts: 314
Hi
isn't easier apply Vp on the chart and set VP to display only P&V ?
[2014-12-06 16:26:02]
Hii, if it can be done yes definitely a good way, but doesn't look one can only show P&V without displaying the VP itself?
[2014-12-07 11:29:57]
Hi
something like this can be ok ?
http://www.sierrachart.com/image.php?l=1417951746309.png
[2014-12-07 11:32:14]
this :D
http://www.sierrachart.com/image.php?l=1417951913991.png
[2014-12-07 16:32:37]
that would be great yes (if the lines we see are peaks & valleys without displaying the vp itself yes!), but no idea how you did it.. ?
[2014-12-07 21:17:28]
just play with settings
draw volume profile outline only : YES
maximum volume bar width percentage to 1
under Subgraphs tabs set volume bars outline and fill colors to visible , width 1 , set color to black for both.
[2014-12-08 09:02:56]
thanks. It works on a normal candle chart, not on a footprint chart. I can see the VP profile but no P&V
[2014-12-08 12:53:30]
http://www.sierrachart.com/image.php?l=1418043159980.png
[2014-12-08 13:10:58]
Thanks Crazy bear, but ain't working for me.. The again Peaks & Valleys sometimes work, some time do not, some time you only get Peaks and other times just Valleys. Very unreliable indeed.
