Date/Time: Wed, 05 Feb 2025 09:57:44 +0000
Peaks & valleys not showing
View Count: 1095
[2014-12-03 08:35:09] |
Dom7364 - Posts: 257 |
Any reason why Peaks & valleys are not showing on the VP (and are obvioulsy selected to show on the chart)? Thanks |
[2014-12-03 08:56:44] |
Make sure you have set the Extend Peaks and Valleys input setting to something other than to None.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-03 21:41:45
[2014-12-03 09:05:12] |
it is set to "until future interesection" and does not show anything. If I change it to anything else (other than none" it works.
[2014-12-03 21:41:28] |
We will check on this.
[2014-12-04 15:07:47] |
Al SC Developer - Posts: 434 |
This should be addressed in ver 1215.
