Date/Time: Mon, 23 Dec 2024 06:20:51 +0000
Missing data on SPY 12/1
View Count: 1097
[2014-12-03 05:07:44]
User53441 - Posts: 17
Hey using the SC Historical feed and for trading day 12/1 my data starts from 9:49 missing the first 19 minutes of the day, can you check this out.
[2014-12-05 04:55:58]
We are checking into this.
[2014-12-05 18:46:25]
We have been told that due to a network issue, this data is lost .
[2014-12-05 19:04:51]
So this cant be fixed? Can I add the data manually somehow?
[2014-12-08 05:13:42]
We can patch this for you, but it will take a little effort. We will work on it this week.
[2014-12-13 03:30:42]
This data has been patched but it has been patched only through the Sierra Chart Exchange Data Feed since we only have control over that data.
Do you just require 1 minute data?
Date Time Of Last Edit: 2014-12-13 03:31:04
[2014-12-14 15:40:11]
If I get the 1 minute data corrected wouldn't the 5,10 and 20 minute data be updated as well?
[2014-12-18 01:36:36]
We apologize for the delay.
Yes, it will be. We can attach a file.
[2014-12-18 04:20:41]
Yes that works thanks
[2014-12-18 04:23:47]
The file is attached.
attachmentSPY.scid - Attached On 2014-12-18 04:23:35 UTC - Size: 6.97 MB - 472 views
