Date/Time: Wed, 05 Feb 2025 09:59:46 +0000
Alerts
View Count: 1018
[2014-12-02 23:20:35] |
User34184 - Posts: 2 |
I'm using Range per bar-new bar when range is met (in ticks) with candlesticks and wanted to know if there is a way make it sound an alert when a new bar is formed on the chart? Please advise. Thanks Jon Paden |
[2014-12-02 23:44:54] |
This can be done by using the Countdown Timer study. It has an input to enable an Alert for a new bar.
[2014-12-04 01:54:24] |
