Date/Time: Thu, 13 Mar 2025 16:39:22 +0000
DOM: changing default position size buttons
View Count: 1064
[2014-12-02 18:16:44] |
EuropeanTrader - Posts: 290 |
Hi, I can't fidn the instructions on how to change these buttons (att. pic) for default position size. Thanks |
![]() Attachment Deleted. |
[2014-12-02 18:41:25] |
You can change the quantities of those buttons by selecting the Set tab.
