Date/Time: Mon, 14 Sep 2026 15:06:57 +0000
S&P CME not FOREX
View Count: 1140
| [2014-12-02 18:05:49] |
| User71644 - Posts: 1 |
Hi, i've installed Sierra and trying to study simbols etc. Here's my question: opening the "Find Symbols" window and inside "Instance" there is "FXCM". What if i need to change for the Mini S&P500 CME instead of FOREX? Regards Claudio |
| [2014-12-02 18:40:08] |
Since you are on a trial, the easiest way to get this data is to use the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
