Date/Time: Fri, 19 Apr 2024 13:59:06 +0000
What does it mean when a chart says it's chart number "3LE"
View Count: 1685
[2013-05-18 02:58:53] |
pe1111112 - Posts: 35 |
I know how each chart is numbered down in the corner, and how green means you're scrolled all the way to the present (meaning you'll see the current bar developing), and red means you've scrolled back a bit, but some of my charts have letters after the numbers. For example: 3LE 2L What do these letters mean? Sorry if I missed this in the help topics somewhere. Date Time Of Last Edit: 2013-05-18 02:59:29
[2013-05-20 23:55:42] |
This is documented here: http://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html#LRChartSettingsIndicators Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-21 01:17:49] |
Thanks. I didn't realize the number was the spacing between bars. I thought it was chart number. I had a bunch of charts open and saw one said 10 and figured it was the 10th chart I opened. |
