Date/Time: Fri, 02 Oct 2026 20:54:20 +0000
Keyboard Shortcut Issues
View Count: 1131
| [2014-12-02 16:57:55] |
| User38993 - Posts: 61 |
Hello I just started using Sierra Chart today, so it might be a dumb question, but here you go. 1. I am looking to use keyboard shortcut to initiate OCO order using market entry. I was able to do this with CTRL + Z. Sometimes my DOM isn't active so my keyboard shortcut doesn't work. How do I make it so that my dom is always active so that whenever I use keyboard shortcut, the order gets in. |
| [2014-12-02 17:40:07] |
We do not know how to help with this. Basically you need to click on its title bar to make it active. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-02 17:40:34
