Date/Time: Thu, 18 Apr 2024 19:15:40 +0000
[User Discussion] - Pivot Points study showing different values on different timefra
View Count: 2209
[2013-05-18 00:44:06] |
pe1111112 - Posts: 35 |
On a 5,000 volume ES chart for today, R1 is just above 1,656.00. On a 5 second ES chart for today, R1 is just above 1,657.25. See attachment. Thanks! |
pivot points.png / V - Attached On 2013-05-18 00:43:43 UTC - Size: 31.69 KB - 545 views |
[2013-05-18 01:09:21] |
Please see: http://www.sierrachart.com/index.php?l=doc/helpdetails65.html This is all the help we can provide for this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-18 01:09:42
[2013-05-18 04:19:01] |
M5amhan - Posts: 468 |
try opening a historical chart in the same chartbook, using settlement closes will give you most accurate pivots since all the institutions and hedge/mutual funds base their data on the settlement close. when setting up the pivots select no on "Use this intraday chart" option and select the historical chart you opened as the daily chart number.. this will now give you the same pivots for any chart you use, and they will be based on settlement rather than midnight which really has no importance
