Date/Time: Tue, 29 Sep 2026 12:35:17 +0000
Non-Chart Data with multiple instances
View Count: 1329
| [2014-12-01 12:26:55] |
| User64410 - Posts: 14 |
I use IQ feed data and IB broker. So i have 2 instances installed. In IB instance I have checked "Use Non-Chart Data From Remote Instances" "Current traded ask/bid volume" uses still snapshot(non-tick) data from IB. Is any possibility to calculate "Current traded ask/bid volume" from IQ feed data in IB instance? second question: sometimes happens that market depth in IB instance do not show Tiers far from actually traded ask/bid. |
| [2014-12-01 13:19:28] |
Update! After restarting all instances i got this: Market depth looks stable at all Tiers. TaS is correct to IQfeed instance. BUT Current Traded Bid/Ask Volume is not present. |
| [2014-12-02 01:02:01] |
"Current traded ask/bid volume" uses still snapshot(non-tick) data from IB. Is any possibility to calculate "Current traded ask/bid volume" from IQ feed data in IB instance? Yes, this is true and no, this cannot be supported. For a solution to this we recommend using the Sierra Chart Exchange Data Feed instead: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php Also, the reason why there may be a problem with the communication of data between Sierra Chart instances is documented here: http://www.sierrachart.com/index.php?page=doc/MultipleServices.html#SharingWithAdminAccess For the Graphics Problem, check the color settings. Refer to: http://www.sierrachart.com/index.php?page=doc/helpdetails9.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
