Date/Time: Sat, 21 Dec 2024 12:39:02 +0000
connection - recon wait
View Count: 1207
[2014-11-30 15:46:58] |
User245469 - Posts: 6 |
Hi, last weeek says mi my SCH recon wait or waiting connection. Some time connection came back but today nothing.Coud you help me where is problem? Thanks
[2014-11-30 20:12:00] |
This is not unusual over the weekend when using Rithmic. Wait until Sunday evening and see if you still have a problem then. Open Window >> Show/Hide Message Log, to open the Message Log. In the Message Log you will see the reason for the connection problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-30 20:12:54
