Date/Time: Sat, 21 Dec 2024 12:47:33 +0000
Non .NET Version of Sierra Chart
View Count: 1047
[2014-11-29 22:32:47] |
yoytu - Posts: 59 |
http://www.sierrachart.com/index.php?page=doc/helpdetails56.html When later updating Sierra Chart to a newer version, make certain that you use the Help >> Download Latest Non-.NET Version command on the menu to get the version that does not depend upon CLR/.NET.
the option to download the non .net version is not available on 1214 version |
[2014-11-29 22:41:46] |
This is known as: "(New Spreadsheets)"
