Date/Time: Sat, 21 Dec 2024 12:37:54 +0000
FXCM SC forex data working?
View Count: 994
[2014-11-28 19:41:36] |
EuropeanTrader - Posts: 290 |
Hi, it seems my SC is unable to load live data from FXCM SC forex data. Is there a problem? http://www.sierrachart.com/image.php?l=1417203625284.png thanks |
[2014-11-28 20:08:40] |
That is not a SC Forex Data Symbol that you show in the chart image. For the supported symbols, select File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
