Date/Time: Sat, 21 Dec 2024 12:46:07 +0000
Do Numbers Bars Work with FXCM Tick Volume?
View Count: 1097
[2014-11-28 15:57:36] |
Halco - Posts: 92 |
Thanks.
[2014-11-28 18:38:21] |
Yes. When using FXCM, Sierra Chart maintains Trade Volume, Bid Volume and Ask Volume which will work with Numbers Bars.
