Date/Time: Wed, 09 Sep 2026 07:42:34 +0000
How to print spreadsheet alert/system columns o-z drawings near current price and not at 1.0000
View Count: 1218
| [2014-11-28 09:43:40] |
| 4646ed - Posts: 231 |
I put a spreadsheet system/alert on a chart of the EURUSD, put formulas in columns K thru N -- their drawings display correctly above or below the highs or lows. I put formulas in column "O" or "P" and they display down at 1.000. How do I change this? I already changed the value format setting to .0001 for all the studies involved, but that doesn't help either. |
| [2014-11-28 10:09:11] |
What you need to do is have the formula return the High or Low for the bar. For example you can use a formula similar to the following to put an arrow on the high: =IF(E3 >1.3000, C3, FALSE) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-28 10:10:03
| [2014-11-28 21:05:08] |
The documentation will be updated to explain this.
