Date/Time: Fri, 17 Jan 2025 06:11:46 +0000
symbol
View Count: 1011
[2014-11-27 19:01:30] |
User502561 - Posts: 36 |
HI I find some difficult to put the symbol on the platform I would like get spread for the CL future but i wasn't able to make spread and downloading the intraday and historical data.I use Interactive brokers. could you please help me? Thanks in advance |
[2014-11-27 21:02:53] |
The best way to do this with Interactive Brokers would be to open 2 charts that you want to calculate a spread for and use the Difference study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-11-28 12:17:59] |
Could you please tell me the simbol that I need to put into system for cl 02-2015 I wrote cl-201502-globex like in the web site tell me but didn't work I couldn't put as well es-201412-globex please let me know what I need to do for get the wti oil contranct in different months thanks in advance Date Time Of Last Edit: 2014-11-28 16:47:21
[2014-11-28 20:20:38] |
These are futures symbols. Refer to this section about futures data: http://www.sierrachart.com/index.php?page=doc/data.php#FuturesData What we recommend you use is the Sierra Chart Historical Data Service for this data: http://www.sierrachart.com/index.php?page=SierraChartHistoricalData.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-28 20:21:46
[2017-12-07 10:12:29] |
Could you please give me the simbol for bitcoin future for sierra chart? thanks |
[2017-12-07 10:14:51] |
Follow the instructions here: https://www.sierrachart.com/index.php?page=doc/Bitcoin.php We recommend using BitMEX and the symbol is XBTUSD-BMEX Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
