Date/Time: Tue, 22 Sep 2026 05:00:05 +0000
FXCM FIX trading
View Count: 2378
| [2014-11-27 17:50:37] |
| EuropeanTrader - Posts: 290 |
Hi, I noticed you offer FXCM FIX for live fx & cfd trading. Is this true? Because I can't find SC name in their "platforms list": http://www.fxcm.com/uk/platforms/overview/ If you do offer a connection, do you maybe know if it can be used for Standard account (2k minumum) or their Activetrader account (25k minumum), since they state that API is only available on the later one... http://www.fxcm.com/uk/services/compare-account-types/ I was talking with their customer representative, but unfortunately he doesn't know anything about it, he was checking Sierrachart.com to see if there is a connection. Thanks! Date Time Of Last Edit: 2014-11-27 17:54:07
| [2014-11-28 03:20:33] |
FXCM is supported: http://www.sierrachart.com/index.php?page=doc/FXCMTrading.php It can be used with a FXCM standard account. Not sure about an active trader account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
