Date/Time: Tue, 29 Sep 2026 14:57:02 +0000
Delete .scid files.
View Count: 1903
| [2014-11-26 19:15:38] |
| Rhuz - Posts: 5 |
Hi i would like to delete some scid files that i no longer use and i would like to know what files are the ones attached to my currrent active chartbooks. Thanks. |
| [2014-11-26 20:02:46] |
Intraday data files with the scid file extension have the symbol as the main part of the filename. So you can delete the data files for symbols that you are no longer using.
| [2014-11-26 20:09:10] |
| Rhuz - Posts: 5 |
And what about the symbols i still use, for example i have a lot of ES files but i don't know which ones are still useful, are the ones that have the most recent "date modified" on them?
Date Time Of Last Edit: 2014-11-26 20:09:28
| [2014-11-26 20:13:02] |
As far as which ones are useful, you need to make this determination. We would not know. If the symbol is expired and you are not using Continuous Futures Contract charts, then you can delete them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-26 20:13:17
