Date/Time: Sat, 21 Dec 2024 12:54:46 +0000
[User Discussion] - background
View Count: 933
[2014-11-26 09:28:23] |
User62940 - Posts: 15 |
Hello 2 questions How to change the background of the platform (not the charts background )actually it's gray per default how to create a tools bar on a detached chart thanks |
[2014-11-26 18:54:10] |
The background color you are referring to is controlled by the Windows operating system. ToolBars are not yet supported on detached charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-11-26 19:08:57] |
do you mean I cannot change the color of the background ?
