Date/Time: Sat, 21 Dec 2024 13:00:27 +0000
Query the name of the indicator.
View Count: 927
[2014-11-26 03:08:37] |
2garin - Posts: 184 |
Good day. Please let me know the name of the indicator in question in the message: http://www.sierrachart.com/supportboard/showpost.php?p=201022&postcount=3 and whether he had updatings? In the list of Technical Studies References that name is not found. Thank you. |
[2014-12-04 00:13:00] |
Good day. You can find out the cause of ignoring my question? |
[2014-12-04 00:28:58] |
If this still exists, it can be found in Analysis >> Studies >> Add Custom StudyUser Contributed Studies.
[2014-12-08 10:41:28] |
Hello. I wanted to know: the name of the indicator that you've added to the list of terminal? (similar to Delta Divergence, discussed in this post). You answer me how to add indicators. |
