Date/Time: Sun, 22 Dec 2024 01:09:38 +0000
Placing Different Charts in Same Window for Same Contract
View Count: 979
[2014-11-24 21:29:14] |
User121729 - Posts: 37 |
I want to place (for the same symbol), 2 charts in different chart regions.. Say in region 1 I want a 3range chart and in region 2 I want a 1 minute chart. Can this be done and if so, how do I do it? Thanks |
[2014-11-24 21:34:30] |
Yes this can be done. Refer to help topic 28 here: Http://www.sierrachart.com/index.php?page=doc/helpdetails28.html You will need to use the Study/Price Overlay study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
