Date/Time: Sun, 22 Dec 2024 06:28:12 +0000
HttpSendRequest failed. Window error code 2....Cant get live data from Barchart.com
View Count: 1140
[2014-11-24 16:38:20] |
sparky36 - Posts: 21 |
Cant login to barchart.com to get data. I called them and they are fine on their end. The full message is: HttpSendRequest failed: Windows error code 2. The system cannot find the filed specified. 2014-11-24 09:29:49 Barchart: Verification of username status failed Thanks for you help. btw..I am running v. 1152 |
[2014-11-24 17:36:24] |
This problem is most likely because Internet Explorer is set to work off-line. Refer to the documentation here about HTTP: Sierra Chart - Software Login Instructions: Login Problems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
