Date/Time: Sun, 22 Dec 2024 01:05:46 +0000
Chart Template
View Count: 1656
[2014-11-24 04:57:49] |
wingz - Posts: 121 |
I downloaded chart template(ending in .cht) into my data folder but it's not showing up in my Analysis list so I can apply to a chart. How do I get it from the Data folder into the Analysis list so I can apply it to a chart please?
[2014-11-24 05:05:08] |
It will only show up when you select File >> Open Chartbook. This is a Chartbook. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-11-24 08:24:47] |
Aaaah....gotcha. I thought it was just a chart template......but....now the chartbook won't open. I'm getting some sort of message saying there was an invalid field code. I'll attach the log. If you can tell me what the problem is I can, hopefully, get it fixed. Software version: 1205 | 2014-11-24 03:15:25 Usage end date: 2014-12-28 | 2014-11-24 03:15:25 Enabled for: Advanced Features. | 2014-11-24 03:15:25 Enabled for: Sierra Chart Historical Data Service. | 2014-11-24 03:15:25 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-11-24 03:15:25 Active service: TransAct Trading | 2014-11-24 03:15:25 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-11-24 03:15:25 2014-11-24 03:15:25 Local computer clock time | 2014-11-24 03:15:25 2014-11-24 08:15:25 GMT time | 2014-11-24 03:15:25 2014-11-24 03:15:25 Time zone adjusted time | 2014-11-24 03:15:25 Time difference to server time: 1 seconds. | 2014-11-24 03:15:25 Program path: C:\SierraChart\ | 2014-11-24 03:15:25 Data Files path: C:\SierraChart\Data\ | 2014-11-24 03:15:25 OS Version Number: 6.1 | 2014-11-24 03:15:25 Locale Information: C | 2014-11-24 03:15:25 Checking for new symbol settings for ta | 2014-11-24 03:15:25 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 88.198.13.175 | 2014-11-24 03:15:25 HTTP connection to www.sierrachart.com:80 (1088) | Connected. | 2014-11-24 03:15:25 Symbol settings are up-to-date for ta | 2014-11-24 03:15:25 Files to Open on Start up | Opening file: Weekly Bar Chart Book.cht | 2014-11-24 03:15:28 Files to Open on Start up | Opening file: Daily ES & YM Chartbook.cht | 2014-11-24 03:15:28 Date rule based rollover from YMM3 to next contract occurs at 2013-06-13. | 2014-11-24 03:15:29 Date rule based rollover from YMU3 to next contract occurs at 2013-09-12. | 2014-11-24 03:15:29 Date rule based rollover from YMZ3 to next contract occurs at 2013-12-12. | 2014-11-24 03:15:29 Date rule based rollover from YMH4 to next contract occurs at 2014-03-13. | 2014-11-24 03:15:29 Intraday data file for YMM3 exists and is empty. Skipping Intraday data download. | 2014-11-24 03:15:29 Checking Daily data file for symbol YMM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-11-24 03:15:29 Intraday data file for YMU3 exists and is empty. Skipping Intraday data download. | 2014-11-24 03:15:29 Checking Daily data file for symbol YMU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-11-24 03:15:29 Intraday data file for YMZ3 exists and is empty. Skipping Intraday data download. | 2014-11-24 03:15:29 Checking Daily data file for symbol YMZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-11-24 03:15:29 Checking Intraday data file for symbol YMH4 for the date range from 2013-12-12 to 0. | 2014-11-24 03:15:29 Checking Daily data file for symbol YMH14 for the date range from 2013-12-12 to 2014-11-24. | 2014-11-24 03:15:29 YMH4 [CB] 405 Min #11 | Symbols used for continuous contract chart: | 2014-11-24 03:15:29 YMM3 | 2014-11-24 03:15:29 YMU3 | 2014-11-24 03:15:29 YMZ3 | 2014-11-24 03:15:29 YMH4 | 2014-11-24 03:15:29 YMH4 [CB] 405 Min #11 | Waiting for historical downloads to complete with the IDs: 1, | 2014-11-24 03:15:29 ES# [CB] Daily #12: No contract months found for symbol. Unable to build continuous futures contract chart. | 2014-11-24 03:15:29 ES# [CB] Daily #12: There are no continuous futures contract symbols. Loading data normally. | 2014-11-24 03:15:29 Files to Open on Start up | Opening file: Inside Bar Chartbook.cht | 2014-11-24 03:15:30 Files to Open on Start up | Opening file: Test Chart Book 7.cht | 2014-11-24 03:15:30 Files to Open on Start up | Opening file: BB Chartbook.cht | 2014-11-24 03:15:31 Files to Open on Start up | Opening file: I - Scalper Chartbook.cht | 2014-11-24 03:15:31 Files to Open on Start up | Opening file: 9 - 30 Test ChartBook.cht | 2014-11-24 03:15:33 HD Request # 2 | Downloading Historical Daily chart data for YMH14. Starting date: 2014-03-20. Service: ta | 2014-11-24 03:15:34 Historical data download counter reset. | 2014-11-24 03:15:34 HD Request # 2 | Requesting historical Daily data for YMH14 starting at 2014-03-19 | 2014-11-24 03:15:34 HTTP connection to www.sierrachart.com:80 (1088) | Closed. No error. | 2014-11-24 03:15:34 HTTP connection to www.sierrachart.com:80 (1088) | Shutdown and closed. | 2014-11-24 03:15:34 Intraday data recording state for symbol YMZ4 is set to pending. | 2014-11-24 03:15:34 HD Request # 3 | Downloading Intraday chart data for YMZ4 to the file YMZ4.scid. Service: ta | 2014-11-24 03:15:34 HD Request # 3 | Download start Date-Time: 2014-11-24 00:19:02.0 | 2014-11-24 03:15:34 HD Request # 3 | Using server: ds3.sierracharts.com port 10149 | 2014-11-24 03:15:34 Intraday data recording state for symbol ESZ4 is set to pending. | 2014-11-24 03:15:34 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-11-24 03:15:34 Intraday data recording state for symbol NQZ4 is set to pending. | 2014-11-24 03:15:34 Intraday data recording state for symbol TFZ4 is set to pending. | 2014-11-24 03:15:34 Intraday data recording state for symbol TICK-NYSE is set to pending. | 2014-11-24 03:15:34 Intraday data recording state for symbol ESM4 is set to pending. | 2014-11-24 03:15:34 Socket (844) | Connected. | 2014-11-24 03:15:34 HD Request # 3 | Sending historical data logon request message. | 2014-11-24 03:15:34 HD Request # 3 | Requesting Intraday data. Start Date-Time: 2014-11-24 00:19:02. Record interval: 2. Symbol: YMZ4 | 2014-11-24 03:15:35 HD Request # 3 | Historical data for YMZ4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-11-24 03:15:35 Socket (844) | Shutdown and closed. | 2014-11-24 03:15:35 The network socket for historical data has been closed. | 2014-11-24 03:15:35 HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YMZ4 | 2014-11-24 03:15:35 HD Request # 3 | Intraday download COMPLETE for YMZ4. Completion time: 1s. Unique request ID: 10 | 2014-11-24 03:15:35 Removed historical data download ID 10 | 2014-11-24 03:15:35 HD Request # 4 | Downloading Intraday chart data for ESZ4 to the file ESZ4.scid. Service: ta | 2014-11-24 03:15:35 HD Request # 4 | Download start Date-Time: 2014-11-24 00:18:52.0 | 2014-11-24 03:15:35 HD Request # 4 | Using server: ds5.sierracharts.com port 10149 | 2014-11-24 03:15:35 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-11-24 03:15:35 Socket (1636) | Connected. | 2014-11-24 03:15:35 HD Request # 4 | Sending historical data logon request message. | 2014-11-24 03:15:35 HD Request # 4 | Requesting Intraday data. Start Date-Time: 2014-11-24 00:18:52. Record interval: 2. Symbol: ESZ4 | 2014-11-24 03:15:36 HD Request # 4 | Historical data for ESZ4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-11-24 03:15:36 Socket (1636) | Shutdown and closed. | 2014-11-24 03:15:36 The network socket for historical data has been closed. | 2014-11-24 03:15:36 HD Request # 4 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ4 | 2014-11-24 03:15:36 HD Request # 4 | Intraday download COMPLETE for ESZ4. Completion time: 1s. Unique request ID: 11 | 2014-11-24 03:15:36 Removed historical data download ID 11 | 2014-11-24 03:15:36 HD Request # 5 | Downloading Intraday chart data for NQZ4 to the file NQZ4.scid. Service: ta | 2014-11-24 03:15:36 HD Request # 5 | Download start Date-Time: 2014-11-24 00:18:43.0 | 2014-11-24 03:15:36 HD Request # 5 | Using server: ds4.sierracharts.com port 10149 | 2014-11-24 03:15:36 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-11-24 03:15:36 Socket (844) | Connected. | 2014-11-24 03:15:36 HD Request # 5 | Sending historical data logon request message. | 2014-11-24 03:15:36 HD Request # 5 | Requesting Intraday data. Start Date-Time: 2014-11-24 00:18:43. Record interval: 2. Symbol: NQZ4 | 2014-11-24 03:15:37 HD Request # 5 | Historical data for NQZ4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-11-24 03:15:37 Socket (844) | Shutdown and closed. | 2014-11-24 03:15:37 The network socket for historical data has been closed. | 2014-11-24 03:15:37 HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQZ4 | 2014-11-24 03:15:37 HD Request # 5 | Intraday download COMPLETE for NQZ4. Completion time: 0s. Unique request ID: 12 | 2014-11-24 03:15:37 Removed historical data download ID 12 | 2014-11-24 03:15:37 HD Request # 6 | Downloading Intraday chart data for TFZ4 to the file TFZ4.scid. Service: ta | 2014-11-24 03:15:37 HD Request # 6 | Download start Date-Time: 2014-11-24 00:12:56.0 | 2014-11-24 03:15:37 HD Request # 6 | Using server: ds3.sierracharts.com port 10149 | 2014-11-24 03:15:37 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-11-24 03:15:37 Socket (1724) | Connected. | 2014-11-24 03:15:37 HD Request # 6 | Sending historical data logon request message. | 2014-11-24 03:15:37 HD Request # 6 | Requesting Intraday data. Start Date-Time: 2014-11-24 00:12:56. Record interval: 2. Symbol: TFZ4 | 2014-11-24 03:15:37 HD Request # 6 | Historical data for TFZ4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-11-24 03:15:37 Socket (1724) | Shutdown and closed. | 2014-11-24 03:15:37 The network socket for historical data has been closed. | 2014-11-24 03:15:37 HD Request # 6 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TFZ4 | 2014-11-24 03:15:37 HD Request # 6 | Intraday download COMPLETE for TFZ4. Completion time: 0s. Unique request ID: 13 | 2014-11-24 03:15:37 Removed historical data download ID 13 | 2014-11-24 03:15:37 HD Request # 7 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2014-11-24 03:15:37 HD Request # 7 | Download start Date-Time: 2014-11-21 19:59:57.0 | 2014-11-24 03:15:37 HD Request # 7 | Using server: ds5.sierracharts.com port 10149 | 2014-11-24 03:15:37 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-11-24 03:15:37 Socket (1636) | Connected. | 2014-11-24 03:15:37 HD Request # 7 | Sending historical data logon request message. | 2014-11-24 03:15:37 HD Request # 7 | Requesting Intraday data. Start Date-Time: 2014-11-21 19:59:57. Record interval: 2. Symbol: TICK-NYSE | 2014-11-24 03:15:37 HD Request # 7 | Decompressing data. | 2014-11-24 03:15:37 HD Request # 7 | Historical data for TICK-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-11-24 03:15:37 Socket (1636) | Shutdown and closed. | 2014-11-24 03:15:37 The network socket for historical data has been closed. | 2014-11-24 03:15:37 HD Request # 7 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK-NYSE | 2014-11-24 03:15:37 HD Request # 7 | Intraday download COMPLETE for TICK-NYSE. Completion time: 0s. Unique request ID: 14 | 2014-11-24 03:15:37 Removed historical data download ID 14 | 2014-11-24 03:15:37 HD Request # 8 | Downloading Intraday chart data for ESM4 to the file ESM4.scid. Service: ta | 2014-11-24 03:15:37 HD Request # 8 | Download start Date-Time: 2014-06-20 09:30:02.0 | 2014-11-24 03:15:37 HD Request # 8 | Using server: ds4.sierracharts.com port 10149 | 2014-11-24 03:15:37 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-11-24 03:15:37 Socket (844) | Connected. | 2014-11-24 03:15:38 HD Request # 8 | Sending historical data logon request message. | 2014-11-24 03:15:38 HD Request # 8 | Requesting Intraday data. Start Date-Time: 2014-06-20 09:30:02. Record interval: 2. Symbol: ESM4 | 2014-11-24 03:15:38 Socket (844) | Shutdown and closed. | 2014-11-24 03:15:38 The network socket for historical data has been closed. | 2014-11-24 03:15:38 HD Request # 8 | Historical data for ESM4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-11-24 03:15:38 HD Request # 8 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM4 | 2014-11-24 03:15:38 HD Request # 8 | Intraday download COMPLETE for ESM4. Completion time: 1s. Unique request ID: 15 | 2014-11-24 03:15:38 Removed historical data download ID 15 | 2014-11-24 03:15:38 HTTP request #1 returned the following error: Windows error code 12029: A connection with the server could not be established | 2014-11-24 03:15:55 HD Request # 2 | Download from the SC Historical Data service failed due to a HTTP error. | 2014-11-24 03:15:55 * HD Request # 2 | Error downloading historical Daily data for YMH14. There was a communication error with the server. | 2014-11-24 03:15:55 * HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YMH14 | 2014-11-24 03:15:55 HD Request # 2 | Daily download COMPLETE for YMH14. Completion time: 21s. Unique request ID: 1 | 2014-11-24 03:15:55 Removed historical data download ID 1 | 2014-11-24 03:15:55 HD Request # 9 | Downloading Historical Daily chart data for IBM. Starting date: 2014-11-20. Service: ta | 2014-11-24 03:15:55 HD Request # 9 | Requesting historical Daily data for IBM starting at 2014-11-19 | 2014-11-24 03:15:55 YMH4 [CB] 405 Min #11: Download is complete for all contract months in chart. Proceeding with data load. | 2014-11-24 03:15:56 YMH4 [CB] 405 Min #11: Performing continuous futures contract back adjustment calculations. | 2014-11-24 03:15:56 YMH4 [CB] 405 Min #11: YMM3 Open price on 2013-06-13 is 14984. | 2014-11-24 03:15:56 YMH4 [CB] 405 Min #11: YMU3 Open price on 2013-06-13 is 14905. | 2014-11-24 03:15:56 YMH4 [CB] 405 Min #11: YMM3 price difference to YMU3 is -79. | 2014-11-24 03:15:56 YMH4 [CB] 405 Min #11: YMU3 Open price on 2013-09-12 is 15339. | 2014-11-24 03:15:56 YMH4 [CB] 405 Min #11: YMZ3 Open price on 2013-09-12 is 15260. | 2014-11-24 03:15:56 YMH4 [CB] 405 Min #11: YMU3 price difference to YMZ3 is -79. | 2014-11-24 03:15:56 YMH4 [CB] 405 Min #11: YMZ3 Open price on 2013-12-12 is 15837. | 2014-11-24 03:15:56 YMH4 [CB] 405 Min #11: YMH4 Open price on 2013-12-12 is 15783. | 2014-11-24 03:15:56 YMH4 [CB] 405 Min #11: YMZ3 price difference to YMH4 is -54. | 2014-11-24 03:15:56 YMH4 [CB] 405 Min #11: Back adjust amount for symbol YMM3 is -212. | 2014-11-24 03:15:56 YMH4 [CB] 405 Min #11: Back adjust amount for symbol YMU3 is -133. | 2014-11-24 03:15:56 YMH4 [CB] 405 Min #11: Back adjust amount for symbol YMZ3 is -54. | 2014-11-24 03:15:56 Intraday data recording state for symbol YMH4 is set to pending. | 2014-11-24 03:15:57 HD Request # 10 | Downloading Intraday chart data for YMH4 to the file YMH4.scid. Service: ta | 2014-11-24 03:15:57 HD Request # 10 | Download start Date-Time: 2014-03-21 09:29:53.0 | 2014-11-24 03:15:57 HD Request # 10 | Using server: ds3.sierracharts.com port 10149 | 2014-11-24 03:15:57 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-11-24 03:15:57 Socket (1724) | Connected. | 2014-11-24 03:15:57 HD Request # 10 | Sending historical data logon request message. | 2014-11-24 03:15:57 HD Request # 10 | Requesting Intraday data. Start Date-Time: 2014-03-21 09:29:53. Record interval: 2. Symbol: YMH4 | 2014-11-24 03:15:57 HD Request # 10 | Historical data for YMH4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-11-24 03:15:57 Socket (1724) | Shutdown and closed. | 2014-11-24 03:15:57 The network socket for historical data has been closed. | 2014-11-24 03:15:57 HD Request # 10 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YMH4 | 2014-11-24 03:15:57 HD Request # 10 | Intraday download COMPLETE for YMH4. Completion time: 0s. Unique request ID: 16 | 2014-11-24 03:15:57 Removed historical data download ID 16 | 2014-11-24 03:15:57 HTTP request #2 returned the following error: Windows error code 12029: A connection with the server could not be established | 2014-11-24 03:16:16 HD Request # 9 | Download from the SC Historical Data service failed due to a HTTP error. | 2014-11-24 03:16:16 * HD Request # 9 | Error downloading historical Daily data for IBM. There was a communication error with the server. | 2014-11-24 03:16:16 * HD Request # 9 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for IBM | 2014-11-24 03:16:16 HD Request # 9 | Daily download COMPLETE for IBM. Completion time: 21s. Unique request ID: 2 | 2014-11-24 03:16:16 Removed historical data download ID 2 | 2014-11-24 03:16:16 HD Request # 11 | Downloading Historical Daily chart data for $NYA. Starting date: 2014-11-20. Service: ta | 2014-11-24 03:16:16 HD Request # 11 | Requesting historical Daily data for $NYA starting at 2014-11-19 | 2014-11-24 03:16:16 HTTP request #3 returned the following error: Windows error code 12029: A connection with the server could not be established | 2014-11-24 03:16:37 HD Request # 11 | Download from the SC Historical Data service failed due to a HTTP error. | 2014-11-24 03:16:37 * HD Request # 11 | Error downloading historical Daily data for $NYA. There was a communication error with the server. | 2014-11-24 03:16:37 * HD Request # 11 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for $NYA | 2014-11-24 03:16:37 HD Request # 11 | Daily download COMPLETE for $NYA. Completion time: 21s. Unique request ID: 3 | 2014-11-24 03:16:37 Removed historical data download ID 3 | 2014-11-24 03:16:37 HD Request # 12 | Downloading Historical Daily chart data for YM#. Starting date: 2014-11-20. Service: ta | 2014-11-24 03:16:38 HD Request # 12 | Requesting historical Daily Continuous data for YMZ10 starting at 2014-11-19 | 2014-11-24 03:16:38 HTTP request #4 returned the following error: Windows error code 12029: A connection with the server could not be established | 2014-11-24 03:16:59 HD Request # 12 | Download from the SC Historical Data service failed due to a HTTP error. | 2014-11-24 03:16:59 * HD Request # 12 | Error downloading historical Daily data for YM#. There was a communication error with the server. | 2014-11-24 03:16:59 * HD Request # 12 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YM# | 2014-11-24 03:16:59 HD Request # 12 | Daily download COMPLETE for YM#. Completion time: 21s. Unique request ID: 4 | 2014-11-24 03:16:59 Removed historical data download ID 4 | 2014-11-24 03:16:59 HD Request # 13 | Downloading Historical Daily chart data for $INDU. Starting date: 2014-11-20. Service: ta | 2014-11-24 03:16:59 HD Request # 13 | Requesting historical Daily data for $INDU starting at 2014-11-19 | 2014-11-24 03:16:59 HTTP request #5 returned the following error: Windows error code 12029: A connection with the server could not be established | 2014-11-24 03:17:20 HD Request # 13 | Download from the SC Historical Data service failed due to a HTTP error. | 2014-11-24 03:17:20 * HD Request # 13 | Error downloading historical Daily data for $INDU. There was a communication error with the server. | 2014-11-24 03:17:20 * HD Request # 13 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for $INDU | 2014-11-24 03:17:20 HD Request # 13 | Daily download COMPLETE for $INDU. Completion time: 21s. Unique request ID: 5 | 2014-11-24 03:17:20 Removed historical data download ID 5 | 2014-11-24 03:17:20 HD Request # 14 | Downloading Historical Daily chart data for $INX. Starting date: 2014-11-20. Service: ta | 2014-11-24 03:17:20 HD Request # 14 | Requesting historical Daily data for $INX starting at 2014-11-19 | 2014-11-24 03:17:20 HTTP request #6 returned the following error: Windows error code 12029: A connection with the server could not be established | 2014-11-24 03:17:41 HD Request # 14 | Download from the SC Historical Data service failed due to a HTTP error. | 2014-11-24 03:17:41 * HD Request # 14 | Error downloading historical Daily data for $INX. There was a communication error with the server. | 2014-11-24 03:17:41 * HD Request # 14 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for $INX | 2014-11-24 03:17:41 HD Request # 14 | Daily download COMPLETE for $INX. Completion time: 21s. Unique request ID: 6 | 2014-11-24 03:17:41 Removed historical data download ID 6 | 2014-11-24 03:17:41 HD Request # 15 | Downloading Historical Daily chart data for NQ#. Starting date: 2014-11-20. Service: ta | 2014-11-24 03:17:41 HD Request # 15 | Requesting historical Daily Continuous data for NQZ10 starting at 2014-11-19 | 2014-11-24 03:17:41 Encountered invalid field code (0) while reading Chartbook file: C:\SierraChart\Data\3X.cht | 2014-11-24 03:17:44 * HTTP request #7 returned the following error: Windows error code 12029: A connection with the server could not be established | 2014-11-24 03:18:02 HD Request # 15 | Download from the SC Historical Data service failed due to a HTTP error. | 2014-11-24 03:18:02 * HD Request # 15 | Error downloading historical Daily data for NQ#. There was a communication error with the server. | 2014-11-24 03:18:02 * HD Request # 15 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ# | 2014-11-24 03:18:02 HD Request # 15 | Daily download COMPLETE for NQ#. Completion time: 21s. Unique request ID: 7 | 2014-11-24 03:18:02 Removed historical data download ID 7 | 2014-11-24 03:18:02 HD Request # 16 | Downloading Historical Daily chart data for SPY. Starting date: 2014-11-20. Service: ta | 2014-11-24 03:18:02 HD Request # 16 | Requesting historical Daily data for SPY starting at 2014-11-19 | 2014-11-24 03:18:02 HTTP request #8 returned the following error: Windows error code 12029: A connection with the server could not be established | 2014-11-24 03:18:23 HD Request # 16 | Download from the SC Historical Data service failed due to a HTTP error. | 2014-11-24 03:18:23 * HD Request # 16 | Error downloading historical Daily data for SPY. There was a communication error with the server. | 2014-11-24 03:18:23 * HD Request # 16 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for SPY | 2014-11-24 03:18:23 HD Request # 16 | Daily download COMPLETE for SPY. Completion time: 21s. Unique request ID: 8 | 2014-11-24 03:18:23 Removed historical data download ID 8 | 2014-11-24 03:18:23 HD Request # 17 | Downloading Historical Daily chart data for ES#. Starting date: 2014-11-20. Service: ta | 2014-11-24 03:18:23 HD Request # 17 | Requesting historical Daily Continuous data for ESZ10 starting at 2014-11-19 | 2014-11-24 03:18:23 HTTP request #9 returned the following error: Windows error code 12029: A connection with the server could not be established | 2014-11-24 03:18:44 HD Request # 17 | Download from the SC Historical Data service failed due to a HTTP error. | 2014-11-24 03:18:44 * HD Request # 17 | Error downloading historical Daily data for ES#. There was a communication error with the server. | 2014-11-24 03:18:44 * HD Request # 17 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES# | 2014-11-24 03:18:44 HD Request # 17 | Daily download COMPLETE for ES#. Completion time: 21s. Unique request ID: 9 | 2014-11-24 03:18:44 Removed historical data download ID 9 | 2014-11-24 03:18:44 ES# [CB] Daily #12: No contract months found for symbol. Unable to build continuous futures contract chart. | 2014-11-24 03:18:44 ES# [CB] Daily #12: There are no continuous futures contract symbols. Loading data normally. | 2014-11-24 03:18:44 Encountered invalid field code (0) while reading Chartbook file: C:\SierraChart\Data\3X.cht | 2014-11-24 03:19:30 * Encountered invalid field code (0) while reading Chartbook file: C:\SierraChart\Data\3X.cht | 2014-11-24 03:23:19 * |
[2014-11-24 08:47:00] |
Update Sierra Chart by selecting Help >> Download Current Version. This problem has been resolved with the "Invalid field code" error.
