Date/Time: Sun, 22 Dec 2024 11:16:26 +0000
New Spreadsheets row 2 will not accept a formula
View Count: 1963
[2014-11-23 18:53:41]
Sawtooth - Posts: 4141
The New Spreadsheets will not retain a formula in row 2 of Formula Columns after a Recalculation. I occasionally use this functionality when the formula in row 3 needs a starting value, as in this example:
http://www.sawtoothtrade.com/example-8.html
Is this something that can be corrected?
Date Time Of Last Edit: 2015-08-14 02:14:09
[2014-11-24 00:17:04]
We will look into this.
[2014-12-25 22:37:09]
It is not really suitable to put a formula in the names row 2. Use row 1 instead.
The user appears to be attempting to create a column with indices in descending order. One way they could do this is with the following formula: =$J$30 - ROW() + 3.
[2014-12-25 23:37:44]
OK, that is another way to put the array in ascending order without using row 2, but I also use a formula in row 2 to create a line label, as in the attached pic.
This is one of several examples where the New Spreadsheets have less functionality. I was hoping this one could be removed from the list.
imageFibs of Pivots.PNG / V - Attached On 2014-12-25 23:34:56 UTC - Size: 64.35 KB - 392 views
[2014-12-25 23:54:34]
We will allow a formula in row 2 to name the Subgraph column.
[2015-08-15 23:43:31]
I noticed this has not happened yet. Is it still on your to-do list?
[2015-08-17 21:51:27]
We will get back about this.
Date Time Of Last Edit: 2015-08-17 21:51:37
