Date/Time: Sun, 12 Jan 2025 13:07:02 +0000
Profit Loss Display
View Count: 4966
[2015-10-12 01:43:42] |
We see that it does not currently support OEC FIX, but we will add support for it in the next release coming out by morning.
[2015-10-12 01:50:01] |
Vizhouz - Posts: 6 |
Thank you very much!
[2015-10-12 21:26:16] |
Letting you know this has been released in the latest prerelease and it is also currently supported for LMAX.
[2017-02-16 19:12:01] |
cmb999 - Posts: 211 |
how can this be achieved for futures ? I am trading NIY priced in yen, but would like trade stats to display in USD. I tried the common currency setting in trade settings, but to no effect for IB connection |
[2017-02-17 03:19:45] |
Refer to the documentation for this here: https://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#CommonPLCurrency Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-17 09:13:22] |
i have IB as data connection . . i checked 'Allow Support for Sierra Chart Datafeeds' (i also have subscription to sc data) i set global currency option to USD i put JPY in the currency field for NIY-######-GLOBEX-JPY-500 still showing pnl in yen for trades window . . |
[2017-02-17 19:20:40] |
What is the exact symbol of the chart? And do you have the Profit/Loss Format set to Currency Value for the chart? Refer to: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#ProfitLossDisplay You might also need to reload the chart. So select Chart >> Reload and Recalculate. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-17 19:46:48] |
symbol is NIY-201703-GLOBEX-JPY-500 I had pnl format set to currency for trades window. didn't know about chart settings. tried that too and recalculated still in yen . . |
[2017-02-17 20:24:39] |
We tested this and it works properly for us. We see what the problem is in your case. You are running an older version of Sierra Chart. You must update following these instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Otherwise you cannot use this feature. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-17 20:40:47] |
it's better :) however, it looks like only PnL column is right ? running pnl etc are still in yen . . |
[2017-02-17 23:11:11] |
Provide a screenshot of the particular area you are not seeing the Profit/Loss value reported in the common currency. So we understand exactly where that is. Here are instructions to attach that: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-18 15:23:45] |
running pnl seems to work after i clicked Apply on the Trades window, however the other columns like max drawdown are still in yen for some reason, but it is sufficient for now however, since i upgraded SC, i noticed a new issue which will detail in another post |
