Date/Time: Sun, 22 Dec 2024 06:14:51 +0000
trying to align my 'Studies' Daily OHLC Lines
View Count: 949
[2014-11-22 23:04:20] |
User78926 - Posts: 69 |
Hi there, As per attached I am trying to align my 'Studies' Daily OHLC Lines with my local server time ie start of day NYC [Market Open]. I have used Displacement in Studies however that then offsets it from last candle and does not give the accurate 'reading' [as it is displaced]. Hopefully your answer will apply to the Volume Value Area Lines as well, which has the same problem]. I have read instruction re scrolling forward, however that does not seem to apply yo this question. Thanks in advance Rgds, Mark |
HL-displacement.jpg / V - Attached On 2014-11-22 22:56:09 UTC - Size: 278.03 KB - 347 views Attachment Deleted. |
[2014-11-24 18:48:07] |
This is done through adjusting the Session Times in Chart Settings. Refer to the documentation for the study here: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s137 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
