Date/Time: Mon, 05 Oct 2026 21:04:54 +0000
Study/price overlay and VolumeByPrice
View Count: 2031
[2014-11-21 22:56:33]
Shane - Posts: 31
I would like to overlay all of the peaks and valleys lines from the volume by price study (SG18) on one chart onto another chart.
I've tried using study/price overlay and while I don't get an error no lines are drawn on the target chart.
I've used this approach before to draw a single line (e.g., opening price from a one minute chart drawn on a range bar chart) but it's not working in this case, I suspect because there are multiple lines the VbP subgraph.
Is this supported? Am I doing something wrong? or is there another way to accomplish the same thing?
Example chartbook is attached.
regards,
shane
attachmentVbPOverlayTest.cht - Attached On 2014-11-21 22:56:06 UTC - Size: 108.7 KB - 544 views
[2014-11-21 23:19:50]
This is not supported.
[2015-01-07 13:12:05]
Zdislav - Posts: 73
Is there a way of having Volume By Price Study of two symbols in one window? For example using Overlay Study/Price to display secondary market in a window and using it as a base for Volume by Price study? I tried several similar possibilities and failed.
[2015-01-07 17:02:45]
No. This is not supported.
[2018-02-05 15:39:01]
whats1thingnow - Posts: 418
I want to do the same thing.
Is there a way to have all the peaks, valleys, POC, copied automatically to another chart since the request from 2014?
Thank you!
[2018-02-05 18:50:07]
No, this is not supported. It could be if we were to reimplement how these lines are done in the Volume by Price study but that is not going to come anytime soon.
[2019-07-18 16:45:25]
User722856 - Posts: 81
Are there any future plans for implementing Volume by Price study overlay to another chart?
Thanks.
Best Regards
[2019-07-18 17:12:31]
No, this is not technically possible.
