Date/Time: Fri, 29 Mar 2024 15:47:54 +0000
sc.BaseGraphScaleRangeType
View Count: 1586
[2013-05-17 07:38:52] |
StarLight - Posts: 26 |
Hi support, I could perfectly set my base chart using sc.BaseGraphScaleRangeType to SCALE_CONSTRANGE. But ... I couldnt set the base graph scale const range. Is there a method that I miss? I tried to set sc.ScaleRangeType to SCALE_CONSTRANG with sc.ScaleConstRange = 1.0f. It works on study graph! Thanks ... |
[2013-05-21 01:57:30] |
We will need to add an ACSIL member variable for this.
[2013-05-21 08:49:55] |
Thanks for a Wonderful support by SC .... Could I have a time frame as when the supporting variable will be added? Thanks again ... |
[2013-05-21 09:30:55] |
This has already been released in version 978.
