Date/Time: Sun, 22 Dec 2024 09:57:07 +0000
XAUUSD
View Count: 1558
[2014-11-21 06:42:48]
stephensmart - Posts: 51
xauusd data feed from SC is delayed and not updating this morning, started about 15min ago.
[2014-11-21 08:14:15]
We are not observing a problem with this. Do you still notice the symbol not updating for you?
Maybe you have set the error filter settings too tight. Check the Window >> Show/Hide Message Log to make sure that the data is not getting filtered.
[2014-11-21 08:26:24]
where do i go to see if the data is being filtered, i cant see any reported error regarding that on the message log.I haven't tinkered with any filter settings, left application standard.
[2014-11-21 09:09:12]
Definitely the SC Forex data feed is working properly across all of our servers.
Therefore, refer to help topic 3 in regards to this issue:
Http://www.sierrachart.com/index.php?page=doc/helpdetails3.html
If you see nothing obvious in the Message Log it means the data is not getting filtered.
[2014-11-21 09:18:06]
all seems fine my side now, it was just delayed over that 15min period, thanks.
