Date/Time: Sun, 22 Dec 2024 01:05:35 +0000
Price Format - decimals
View Count: 1116
[2014-11-21 00:46:07]
rhovega - Posts: 279
Can't find a way to change the price format / reduce the number of decimals, in neither the DOM nor the Quoteboard. Only on charts.
Is this not possible?
If not, would you consider adding that functionality?
Seeing insturments such as GBPUSD or USDJPY with half a pip increments is visually quite bothersome.
Thank you
[2014-11-21 18:58:48]
Refer to:
Changing the Price/Value Display Format
