Date/Time: Fri, 22 Nov 2024 13:15:02 +0000
numbers bars calculated values (position)
View Count: 2103
[2013-05-17 06:28:27] |
TradingMarketProfile - Posts: 120 |
Hello, Is it possible for you to add a way to change the position for numbers bars calculated value (up / down) At the moment if i choose delta and total volume, delta is in first position but if i want the volume first i can't Thanks |
[2013-05-17 07:09:46] |
This is not currently supported. We will see about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-17 08:08:45] |
ok thanks
[2013-05-17 18:04:52] |
Al SC Developer - Posts: 434 |
When available, ver 977 will have a new input: Subgraph Display Order. This input is a comma separated list of subgraph numbers (1, 2, 3, etc.). By default this input is blank, which displays the rows in the default order. When values are specified, those subgraphs will be displayed in the specified order. Any subgraphs not specified in the list, will be displayed after those specified. |
