Date/Time: Wed, 05 Feb 2025 19:01:45 +0000
[User Discussion] - color of bars
View Count: 1090
[2014-11-20 19:48:33] |
User28682 - Posts: 233 |
Hi, I noticed that bars that close unchanged are still colored red. This is not a down close, is this right? The volume bars are the same. It is misleading as it looks bearish when this happens in an up move, but its not really a down bar. See examples in my attachment. Is it possible to have this changed? Thanks Tom |
colored_bars.png / V - Attached On 2014-11-20 19:48:22 UTC - Size: 42.8 KB - 372 views |
[2014-11-21 04:41:52] |
The coloring logic of bars is controlled through Global Settings >> Graphics Settings >> Other. In any case, we would not make any changes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-21 04:42:22
