Date/Time: Wed, 05 Feb 2025 19:00:28 +0000
Something wrong with MovAve Cross Scale
View Count: 1351
[2014-11-20 01:45:35]
User60897 - Posts: 6
Need help for the scale of MovAve Cross indicator's scale. (In GBP/USD FXCM)
When I set the indicator's scale for auto, I can not read bars, but I can see the dots;(PIC: auto range)
When I set the indicator's scale for same as region, the chart is normal but i can not see the dots.(PIC: Same as region)
But when I use this indicator in XAUUSD and set scale to auto, it works well, in or other symbols like GBP/USD do not work well. (PIC:Normal)
Thanks!
imageAuto Range.png / V - Attached On 2014-11-20 01:41:16 UTC - Size: 6.24 KB - 337 views
imageSame as region.png / V - Attached On 2014-11-20 01:41:26 UTC - Size: 20.82 KB - 324 views
imagenormal.png / V - Attached On 2014-11-20 01:42:00 UTC - Size: 13.91 KB - 317 views
[2014-11-20 03:10:52]
Are you using the Spreadsheet System/Alert study?
[2014-11-20 03:39:51]
I use add custom study
[2014-11-21 04:33:04]
No one has asked about this study for probably 10 years.
We see the problem and it will be fixed in the next release.
