Date/Time: Sat, 19 Sep 2026 11:40:35 +0000
[User Discussion] - Spreadsheet Rolling Pivot - Session End Time
View Count: 3413
[2014-12-02 15:24:12]
Sawtooth - Posts: 4354
-Set the Formula Source Sheet Number to the same as the chart number where each spreadsheet study is applied, then copy/paste the entire Sheet1 to that respective sheet number.
-Set the Chart Data Output Sheet Number to 0 on all of the spreadsheet studies.
[2014-12-02 16:13:28]
OneMoreTick - Posts: 79
Same result. Would you be able to attach a chartbook with a working version using the session close/open formula?
Date Time Of Last Edit: 2014-12-02 16:17:38
[2014-12-02 20:16:23]
Here you go...
Edit: new files attached with corrected K3 formula
Date Time Of Last Edit: 2014-12-02 22:56:27
attachmentDilernia nPeriod Rolling Pivots.cht - Attached On 2014-12-02 22:55:31 UTC - Size: 29.09 KB - 719 views
attachmentDilernia nPeriod Rolling Pivots.scwbf - Attached On 2014-12-02 22:55:51 UTC - Size: 90.84 KB - 618 views
[2014-12-02 21:21:19]
I finally see the issue. It doesn't work on a daily intraday chart, only smaller intraday charts.
[2014-12-02 23:03:17]
Have you ever considered being a Beta tester? :)
OK, I think the K3 formula will now handle any chart type, any session times, including an Intraday 1-0-0 chart that doesn't start at midnight.
Post #27 has the updated files.
Here's the new K3 formula, if you don't want to download the files:
=IF(OR(AND($J$75>0,MROUND(A3-INT(A3),1/86400)=MROUND($J$75,1/86400)),AND($J$75=0,INT(A3)>INT(A4))),K4+1,K4)
[2014-12-03 02:18:07]
I have been a beta tester :-)
Well that seems to have done it, nice work. I have to set the displacement to 12 and that gets the shift to where I want it at the session close time. Not a big deal. There's just one thing about Mondays. For some reason the pivots shift 3 hrs before the session close on Mondays and then again at the session close. Look at the last 2 Mondays on this chart, I've marked the session close with a vertical line. It doesn't really create a problem since the end of session shift is correct, just curious.
http://www.sierrachart.com/image.php?l=1417572627432.png
[2014-12-03 03:36:45]
I'd need to have your chartbook to answer that. Too many settings and possible configs.
[2014-12-03 04:46:35]
Here you go.
attachmentDilernia v2.cht - Attached On 2014-12-03 04:44:56 UTC - Size: 67.47 KB - 668 views
attachmentDilernia v2.scwbf - Attached On 2014-12-03 04:45:03 UTC - Size: 90.84 KB - 668 views
[2014-12-03 14:25:39]
I'm not able to isolate the problem. It seems to be an anomaly of the Study/Price Overlay study. The daily values are correct in the source chart, but don't overlay on the destination chart as expected after a weekend. Since the source chart is accurate, I don't know what else can be done.
Date Time Of Last Edit: 2014-12-03 14:25:52
[2014-12-03 14:27:08]
Ok, thanks for checking it out.
