Date/Time: Sat, 21 Dec 2024 17:15:50 +0000
AMP CQG
View Count: 1290
[2014-11-19 10:14:40] |
rwilliams1 - Posts: 346 |
Can Amp CQG users now login using the CQG Web Api instead of the AMP CQG login?
[2014-11-20 04:37:50] |
Yes you can. Update to version 1213 of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-20 04:38:03
[2014-11-24 18:34:39] |
Is this new CQG Web Api currently active for Amp customers to use? I just contacted Amp, which they in turn say they contacted you, and was told that this feature will not be up and running for about a month.
[2014-11-24 18:50:40] |
Yes it is active. Have no idea about what AMP said. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-11-24 19:28:56] |
Was just told again by Amp that it won't be ready for at least a month. Hoping you can keep us customers updated on what the status is.
[2014-11-24 19:47:50] |
We do not know what they are referring to.
[2014-11-24 20:00:53] |
I'm not a tech person, so please bear with me regarding terminology. But I was told there is some type of configuration problem on CQG's end where some type of Sierra Chart server file protocol is incompatible and that it will take about a month for it to be sorted out.
[2014-11-24 20:30:24] |
CQG already solved this.
[2014-11-24 20:35:00] |
Well then I am completely confused... Hoping you can contact Amp to get a definite answer because at this point I'm not sure what to believe. I've spent the last few hours and even spoke on the phone with Amp reps who say that this CQG Web Api is not functional at the moment.
[2014-11-24 21:35:05] |
It is functional and we are the best contact for knowing whether it is functional or not. However, we are seeing an intermittent issue with it. So it might be best to wait anyway.
[2014-11-24 22:46:14] |
Ok, thanks for clearing that up. I will wait until you confirm that it is bug free.
[2014-12-17 13:11:15] |
Just checking up on the status of the CQG Web API. Any word on how things are going? Thanks.
[2014-12-19 10:22:18] |
We do not have good confidence in the CQG Web API. We recommend TTNet instead. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
