Date/Time: Sun, 22 Dec 2024 11:29:54 +0000
Drawings on Different Symbols
View Count: 1221
[2014-11-18 15:57:09] |
LadyTrader - Posts: 19 |
When I am using a chartbook and have one symbol up - SPY for instance - I will put some reference lines on the chart. Then, if I change the symbol - to IWM for instance - all the drawings I did on the SPY chart will remain. Is there a way to have the drawings stay with the symbol so that I don't have to keep hiding and unhiding drawings and can easily go through the charts and keep their drawings on them. Thanks for all the help - always is appreciated. |
[2014-11-18 22:28:59] |
Yes. Uncheck Chart >> Chart Settings >> Advanced Settings 2 >>Show Chart Drawings for Different Symbols.
