Date/Time: Tue, 14 Jan 2025 16:02:24 +0000
Market delta data
View Count: 1012
[2014-11-18 13:39:11] |
User80764 - Posts: 10 |
Hi Please look at the imagine attached, as u can see something is not ok with the deltas Let me know were the error is 21X4 a lot of times 0x0 and son on Thanks Greg |
soybean_delta.png / V - Attached On 2014-11-18 13:38:17 UTC - Size: 29.79 KB - 340 views Attachment Deleted. |
[2014-11-18 22:32:33] |
Make sure Sierra Chart is set for a tick by tick data configuration: https://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
