Date/Time: Thu, 24 Sep 2026 09:43:30 +0000
Save TPO Study Settings
View Count: 1511
| [2014-11-17 23:18:16] |
| User998173 - Posts: 1 |
Hi SC, I set up my TPO and volume by price study settings. Then back in chart study settings I save all to a new name which comes up in the drop down list. But if I create a new chart, and want to replicate the same TPO settings this does not work. I select TPO and volume by price studies, add them to the graph, and apply the saved settings but nothing happens. |
| [2014-11-18 00:09:59] |
It sounds like you have saved them as a Study Collection, so you need to apply that Study Collection from the Analysis menu. Here is the documentation: http://www.sierrachart.com/index.php?page=doc/doc_StudyCollections.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-18 00:10:13
