Date/Time: Wed, 30 Oct 2024 22:55:58 +0000
Color of Candles when using Sum study
View Count: 880
[2014-11-17 17:00:43] |
hft168 - Posts: 31 |
Hi S.C. Support, We try to get a chart with two stocks (SPY and IWM) using the SUM study with 1 and -1 as multiplier, and display the sum as main price graph by checking the option in the study. Is there a way to change the setting so it will display both red and green based on the combo value of open and close? For now without any change of settings, it display the summed price graph with all Green candles. Thanks. |
[2014-11-17 18:34:27] |
Check the color settings. Refer to the documentation here: http://www.sierrachart.com/index.php?page=doc/doc_GraphDrawTypesColorSettings.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
