Date/Time: Sat, 21 Dec 2024 17:53:18 +0000
Trading two accounts at different brokers
View Count: 884
[2014-11-17 01:48:28] |
Shane - Posts: 31 |
How would I go about trading two accounts (and do chart trading) at two different brokers, both of whom supply data? Is this even possible? Would installing Sierra Chart twice into two different installation directories work? regards, shane |
[2014-11-17 04:44:38] |
Yes, you need to install two copies of Sierra Chart. This is documented here: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
