Date/Time: Thu, 18 Apr 2024 09:07:05 +0000
[User Discussion] - how do i difine the stop order offset for high/low of the prior
View Count: 1780
[2013-05-16 13:48:33] |
User32496 - Posts: 26 |
when setting group order i can use only the offset feature i need to offset to the high/low of the bar before. your advice will be appriciated also, there is this order type NewOrder.AttachedOrderStopAllType = SCT_ORDERTYPE_TRIGGERED_TRAILING_STOP_LIMIT_10_OFFSETS; is there same with stop market? |
[2013-05-18 21:12:42] |
any idea? any other option? |
[2013-05-20 18:49:40] |
please help thanks |
