Date/Time: Fri, 19 Apr 2024 04:02:05 +0000
Some default 'replay speed buttons'?
View Count: 1768
[2013-05-16 09:51:16] |
User87197 - Posts: 65 |
Hiya, I originally came to Sierra Chart because of the Trade Simulation and Replay features (before falling in love with the rest of it). As a user that makes extensive use of the replay feature, it would be nice if on the 'replay panel' there were some default 'speed buttons' that could be clicked to change playback speed - because having to hit 'Pause' then select the 'Speed' box with the mouse and entering a new value on the keyboard, then un-pausing can be quite tedious if you're speeding up and down through periods of activity and inactivity. A button for "x1" "x2" "x5" "x10 "x50" and "x100" would be awesome and i'm sure users would really like the feature, plus the way you guys make additions i'm sure you could knock that together in no time! Maybe there's something about the way the software handles playback that prevents a one-click speed-change DURING playback but even if that is the case the buttons would still save a lot of effort because you wouldn't need to be reaching for the keyboard all the time. If you do get a chance to consider implementing this I would be super-grateful forever and ever! |
[2013-05-16 22:47:48] |
We will see what we can do.
[2013-05-18 22:45:34] |
This is now done. Please update to the very latest revision of 977 by selecting Help >> Download Prerelease.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-18 22:46:00
[2013-05-20 13:21:57] |
This is even better than what I described because I can just press up/down cursor to cycle through the speeds! Awesome, I can't believe how quickly you implemented this! That's why you've got a customer for life right here. Thanks Sierra Chart, I really appreciate you taking the time to do this!
[2013-05-20 16:15:30] |
Sure thing.
