Date/Time: Fri, 10 Jan 2025 12:56:21 +0000
How to hide candlesticks?Make them invisible
View Count: 2794
[2013-05-15 21:19:50]
User57124 - Posts: 48
I am overlaying HeikenAshi over my candlesticks, the default candlestick is what i want to hide, how do i do this. My current platform has color selection for invisible.
thx for reply
R
[2013-05-15 22:13:43]
M5amhan - Posts: 468
two ways
in the heiken ashi study settings you can check "display as main price graph"
or you can go to chart settings and look at graph type where candlestick bars is selected, scroll all the way down and select blank
Date Time Of Last Edit: 2013-05-15 22:14:19
[2013-05-15 22:51:24]
thx for reply....new to Sierra
[2013-05-16 03:47:16]
You will need to use the Display As Main Price Graph option for the Heiken Ashi study. This is documented here:
http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#SettingsandInputsTab
Date Time Of Last Edit: 2016-09-12 16:59:05
[2016-09-12 16:54:26]
User585624 - Posts: 1
dear Sir or Mdm,
please kindly advice, how to make hidden candlesticks appear at the screen one by one for study purpose.
very often I'm testing different strategies, and for this purpose I need this 1H candles to be hide, and I can see them one after one then I need it, so I can write down on the paper decision that I made based on strategy and I see next candles if this is lost or win position. it is difficult to check strategies on realtime charts, because it is very slow.
please advise if your program has this setting and how to use if any.
thank you
Julia
Date Time Of Last Edit: 2016-09-12 16:57:17
[2016-09-12 17:00:05]
You need to use the Chart Replay feature:
Replaying Charts
