Date/Time: Fri, 22 Nov 2024 13:40:43 +0000
[User Discussion] - High of the current Bar
View Count: 1816
[2013-05-15 20:19:55] |
nepher - Posts: 56 |
Hello, I would like to display the value of the high of the current bar (H-L), is there any standard study that makes the job ? That looks simple, I tried with Countdown study but I was unable to overlay the CountDown study(in RangeBar chart)to put it on other chart. Thank you again. Date Time Of Last Edit: 2013-05-15 20:20:28
[2013-05-15 20:52:23] |
Sawtooth - Posts: 4118 |
Use the Text Display for Study study.
[2013-05-15 21:41:15] |
Hello TomGilb, Thanks for your help but I already tried with Text Display for Study I would like to place the information of CountDown study (in range bar chart) from my chart #10 in my chart #1. I created a Textdisplay for study on #1 and referenced the countdown study from #10. No results, only blank in the chart. Countdown seems to have problem as other studies are working very well (Last/Open/High/Low). Has someone encounter the same problem to overlay countdown study ? Thanks for you help. |
[2013-05-15 22:34:02] |
The CountDown Timer study does not output any values, so it can't be overlaid with success. There is a workaround involving a spreadsheet study, a SMA of a subgraph of that study, an overlay of the SMA, and the Text Display for Study of the overlaid SMA. Yeah, it's a kludge, but it works. If you're interested...... |
[2013-05-16 15:16:56] |
thanks Tomgilb, I found a solution in overlaying the Range Bar Predictor study
