Date/Time: Sat, 21 Dec 2024 12:43:56 +0000
Message Log Pop Ups
View Count: 1044
[2014-11-07 05:55:11] |
rhovega - Posts: 279 |
Message log window pops up every time there is an error or a disconnection. This is extremely inconvenient for multiple reasons, especially given that I run multiple SC instances. Is it possible to disable the pop ups? If not, is it something you would consider implementing? Thank you |
[2014-12-03 19:49:57] |
Hi, Did you see this? I run 8 SC instances, and have to unfortunately rely on a wireless connection - every time I get a half second disconnection I get 8 white SC logs blocking all my views. Annoying does not suffice to describe this. Why do the log have to pop up when something happens? Can't you make this optional? Many thanks |
[2014-12-06 19:18:29] |
We need to see what message is causing the Message Log to open. A message which has an asterisk (*) at the end will cause it to open. Paste that particular message here and it is better for us to maybe make that message not cause the log to open. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-06 19:18:56
