Date/Time: Mon, 24 Feb 2025 02:54:24 +0000
Previous Daily Close
View Count: 2877
[2014-11-05 08:45:40] |
User78442 - Posts: 260 |
Hi, i've been trying to implement a SS study to incorporate measures for ATR Bands & Noise Bands for a new day. My issue is how to incorporate the last day's close. I am looking at CL ETH which closes @ 22:15 London time. I've set the sessions and have a daily chart/data that can be set to intraday which slows the actual daily close. When i try and use the Overlay Bar data and a Daily OHLC combination the daily chart reverts back to the chart time-frame from the SS Study.. any ideas or a better method for getting the previous day's close (the standard Close on historical daily data is incorrect). Many thanks..
[2014-11-05 11:57:47] |
The Daily OHLC study can be set to reference the prior day. So you can use that to get the prior day closing price.
[2014-11-05 12:45:47] |
The Daily OHLC Close that is calculated looks like the settlement price NOT the Close. Yesterday it was calculated at 77.19 for CL whereas the close of Globex (17:15 ET) should have been 77.33 - I need this price i.e. Globex Close NOT the settlement. Can you tell me how I can find this price easily to populate my study. Many thanks
[2014-11-05 12:52:44] |
Use the Daily OHLC study on an Intraday chart and make sure the chart Session Times are set according to what you require. Here is the documentation: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s137 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-05 12:53:04
[2014-11-05 13:27:44] |
Thanks, I've played about and now it looks good!
[2021-03-03 13:02:20] |
User840539 - Posts: 25 |
Good morning, Sierra Support! Got a question regarding backtesting and using previous day close from each day: when I use OHLC, it draws only the previous day close, doenst matter what day it is. Instead, I need the previous day close for each separate day to be shown, like here from ThinkorSwim (see attached file). Is there a way to do that? Also when using Previous Bar Close (and setting input from Quote Board to 'yes'), the study is not drawn for some reason. When I choose "No", then a completely wrong number appears on the chart. Help would be appreciated! Date Time Of Last Edit: 2021-03-03 13:02:50
